Re: Welding cast iron
Posted by Don L C on March 29, 2008 at 14:17:56 from (24.33.90.34):
In Reply to: Welding cast iron posted by STEWARTINPA on March 29, 2008 at 02:06:23:
After you get it welded.....check to see if the gasket surface is flat with a straight edge......it will help if you use two gagkets......tighten the bolts up in about three times tightening on the bolts .....start in the center of both sides......
