Re: 10 ohm resister
Posted by Janicholson on March 30, 2008 at 08:48:31 from (66.173.50.115):
In Reply to: 10 ohm resister posted by 160dan on March 29, 2008 at 19:49:35:
John T and I agree on the reality.
If the item you took off is the ballast resistor that was installed by previous owner, and it is still, or now 12v, aaannnddd the same coil is used as before (12v with external resistor required) it may need to go back in the ignition circuit between the coil and ignition sw. The light, or diode you need is placed in the wire from the #1 terminal on the Alt. and the ignition sw. Any other place will not do it.
JimN
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
