Re: Super-A pressure plate
Posted by Coax on March 30, 2008 at 12:21:32 from (68.26.127.34):
In Reply to: Super-A pressure plate posted by P and R Pete on March 30, 2008 at 12:01:57:
No,the release Bearing presses up against those fingers.So the face of the bearing(and the linkage holding it)needs to be adjusted towards the fingers so when you press the clutch the total travel is 2 3/4"I believe the book has a picture showing how the adjustment works.On Cars the bearing is called a Throwout bearing.All older manual clutches work the same..Mechanically anyway...
