Re: Another question, 560 3PTH
Posted by Armand Tatro on March 30, 2008 at 17:35:10 from (98.227.135.78):
In Reply to: Another question, 560 3PTH posted by casered on March 30, 2008 at 06:53:19:
I cut a piece of heavy wall tubing in half, put it over the rockshaft, and welded it back togather. Than I welded 2 ears on the tubing to anchor the top link with the pin at right angle to the rockshaft. The only thing I would do different would be to add 2 grease zerks. It is a pain to grease it. Armand
