Posted by IaGary on March 31, 2008 at 06:07:39 from (67.55.192.138):
In Reply to: Farmall 460 diesel posted by Bluehorse on March 31, 2008 at 05:22:56:
I"ve been around 560"s all my life.
At one time there were 7 in the neighborhood during the mid 60"s.
2 gassers and 5 diesels. All but 1 on them were pulling 4-16"s plows. The other one was pulling 5-14"s. 3 are still in the neighborhood today.
NOT A SINGLE ONE OF THEM HAD REAREND PROBLEMS.
Never knew a rear end problem exsisted in them till I got on this web site 3 years ago.
There were also 4 460"s in the neighborhood.And none of them had a rearend problem either. Our 460 pulled the planter and harrow for 12 years. And lived under a loader for 25 years. We replaced the clutch 3 years ago and that was the first time to open up the tractor. Still had the orginal engine and all when it burned up in a fire last summer. It was a gasser.
Diesels could be a little tuff to start sometimes but otherwise I think they were a good all around tractor. If you keep the glowplugs working and the battery system in good shape they were fine.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
