Re: Clutch sticking on F-20
Posted by F-Dean on March 31, 2008 at 07:50:35 from (67.72.98.81):
In Reply to: Re: Clutch sticking on F-20 posted by VA Gasman on March 31, 2008 at 03:41:40:
If the klock number is different from the other numbers on a F-20, most likely the block has been changed. Someone may have left water in it some winter - Dad did - and it was damaged beyond repair.
