Re: Farmall 460 diesel
Posted by ihc49er#2 on March 31, 2008 at 07:54:34 from (216.123.197.195):
In Reply to: Farmall 460 diesel posted by Bluehorse on March 31, 2008 at 05:22:56:
we have a 560 in our family for over 40 years and no major problems. only replaced one rear axle brg.no diff. problems.engine was o/h 2 times.very economical on diesel, less than 2 g/hr.doing field work. yard work a tank lasts forever.use the t/a as it was designed for and no problem.mostly dont use it.yes, keep good batt. and glow plugs. hold glow plugs about 40 sec. push starter button and its running in 3or4 engine turns.you need good starter rpm or forget it, it will not start.this is a good example of more amps with 2 - 6 volt batt. than 1- 12 v.overall i will give them a good rating.one more thing is the 560 has much better steering than the 460.in the utlity models.
