Posted by karl f on March 31, 2008 at 16:06:20 from (64.83.221.111):
In Reply to: Farmall H wiring box posted by 160dan on March 31, 2008 at 15:09:16:
160dan said: (quoted from post at 15:09:16 03/31/08) it is a 4-poss switch...I think at the bottom is't rear light, up one="off" up onemore = lowbeam and last up = highbeam. All my manuals show generator and lots of wires to a v-regulator and I have a 12v conversion/alternator
the correct 4 position for an H has only 2 positions for lights. the other two are for charge rate. clockwise L H D B. Low charge, High charge, Dim, Bright
Since you have an alternator conversion, you should have a 3 position switch from an H: O D B; Off, Dim, Bright.
or you can put on a 4 position from a newer such as 56 series: O D B R; Off Dim Bright, Rear worklight.
the H 4-position is NOT the same as the newer 4-position. it is a switch with two seperate switching components built into it.
if you use the H 4-position on your current system, you will have two positions that do nothing (lights off). You cannot easily use those positions like the light terminals since they short to ground.
a continuity tester, voltage tester, multi-meter, and fused jumper wires are your best friends.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
