Re: 460 engine overhaul question
Posted by ScottyHOMEy on March 31, 2008 at 20:30:45 from (71.241.213.254):
In Reply to: 460 engine overhaul question posted by Rifler on March 31, 2008 at 19:21:17:
Try doin' a wet compression test on a cylinder or two at first. Just squirt some oil into a cylinder (just enough to run off the top of the piston and get down to the rings) and recheck the compression. If ti comes up significantly, go ahead and check them all just so you'll know where you stand.
If that doesn't reveal anything, you're going to need to go back through the whole job. Cam timing, valves (fit and adjustment), head gasket . . . and figure out where you're leakin'.
Bummer.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
