Re: farmall super m pulling problem
Posted by Pat-CT on April 01, 2008 at 04:03:02 from (207.210.152.4):
In Reply to: farmall super m pulling problem posted by super_m damnit on March 31, 2008 at 22:09:14:
dont go full throttle it wont stall and if it starts to lug then give it more juice..match the rpm with the bite of the tires if you know what i mean
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
