Check the specific gravity of each battery cell with a hydrometer. This will tell you the condition of the batteries. They should all read around 1.250 or better. You need to fully charge the batteries before doing this. The charging voltage should be near 14.5 volts from your alternator and can be checked with a volt meter with the engine around 1/2 to 3/4 throttle. Unhook the ground cable over night and then see if the tractor will start. If that alternator has an internal regulator it may be the cause of the battery drain. Hal
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
