Re: H and a one row corn picker...
Posted by jal-SD on April 01, 2008 at 06:21:19 from (71.221.57.84):
In Reply to: H and a one row corn picker... posted by jeffalex2 on April 01, 2008 at 05:49:02:
Not a problem, I picked corn w/1-row Woods in 100 bpa corn this fall using my VAC Case as a power unit, it has about 2/3 the horses & half the weight of an H. When I was a kid, Dad, Uncle & Grandpa picked 1000's of acres of corn with an IH 2-P (two row pull type picker) powered by an H, that was purchased on the "black market" right after Uncle came home from WWII. Then they used an IH 24 (2 row mounted on an H) to pick 1000's more after the 2P wore out. (My $0.02 worth. jal-SD)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
