Re: 460 engine overhaul question
Posted by IntHar on April 01, 2008 at 10:41:19 from (75.133.83.75):
In Reply to: Re: 460 engine overhaul question posted by Rifler on April 01, 2008 at 08:29:37:
It sounds as though you may have the timing marks off. While you check that, another thing you should do is check that you have the right crankshaft installed. Doesn't appear that you have enough stroke. It has happened on 560's, where a 460 crank was installed. You could start them by pulling, but couldn't pull a setting hen off the nest. Two ways to check that. One-Thru spark plug opening, use a piece of 1/8 brazing rod and have some one turn the engine slowly while you keep pressure on the rod, and follow the piston to the bottom. Mark rod at opening of plug hole, then proceed to the top of the stroke and mark again. That will give you the approximate stroke. Bet that's part of the problem. The other way would be if you pulled the head, simply measure travel of piston thru the top of bore. Good luck Rifler.
IntHar
