Re: 460 engine overhaul question
Posted by Rifler on April 01, 2008 at 11:57:15 from (204.44.253.2):
In Reply to: Re: 460 engine overhaul question posted by El Toro on April 01, 2008 at 10:15:45:
I need to check the crank as it was was swapped out from the original engine due to too much wear and not enuf to grind to make it good again. The crank guy had a good one ready to go at the time. I never verified it was for a 291 motor, just took his word as it was tagged as one.
The cam gear had two punch marks, but I am not sure I follow you on the cam gear to governor gear alignment. The picture in the manual doesn't look like a C-291 motor.
