Re: farmall super m pulling problem
Posted by Pat-CT on April 01, 2008 at 12:22:44 from (68.110.205.165):
In Reply to: Re: farmall super m pulling problem posted by JThomas on April 01, 2008 at 10:57:31:
JThomas the problem with pulling with a stock drawbar at least mine which i did was the first time i hooked it up to a stone boat when i started to move the chain was so short that the sled lifted up in the front okay but when thats loaded up a bit with weat that draw bar sheared right therew my sliding drawbar so i took a piece of one inch steel and bolted it ontop of the bar..is that modified?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
