Re: Hydraulics on Farmall C
Posted by CNKS on April 01, 2008 at 17:43:59 from (216.144.104.128):
In Reply to: Hydraulics on Farmall C posted by SDP1 on April 01, 2008 at 10:45:47:
As the others say the plumbing is done at the unit under the gas tank, you need a bypass block. the type of connections is not important as long as the hose connection fits it. Unless you are using a lot of different trailing implements, then they all must be the same.
