A lot of tractors have been converted to 12 volt negative ground, and a lot have been cobbled on electrically.
The safest answer will be found by following your cables. Your chassis is your ground. Start with the positive terminal of your battery and follow the cable. If it bolts to some part of the chassis without being interrupted by switches, etc., then you have a positive ground. If that isn't the case, trace the cable back from the negative terminal of the battery and see if it runs directly to ground. If it does, then you need to explore whether you're set up for 6 or 12 volts.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
