Re: 240utility fastitch hydraulic problems
Posted by bc on April 02, 2008 at 00:28:10 from (66.140.173.77):
In Reply to: 240utility fastitch hydraulic problems posted by glennster on March 30, 2008 at 18:51:35:
Thanks Paul. I learned a lot from that flow chart. I also figured out that when the flow is reversed and going in through Q, the piston moves up and the rod on the piston also opens the check ball which allows flow back out through P. It took me a little bit to figure that out cause I thought the check ball would still keep the fluid from coming back through P.
A missing oring on any of those check valve actuator pistons on about any valve setup could account for fluid bypass problems on other things such as power steering.
