Re: 1066 won't start
Posted by rezner on April 02, 2008 at 12:04:38 from (70.146.201.248):
In Reply to: 1066 won't start posted by rezner on April 02, 2008 at 10:42:09:
I will check if I'm getting fuel at the injectors. It is getting some fuel to the pump, I cracked the fitting before the pump and it was wet. Fuel filters are 2 years old. I think I will top off the fuel in the tank as well, its on the low side, judged by using a stick down the tank, fuel gauge won't come on. It worked several weeks ago but won't come on now, nor does the amp gauge show any discharge while cranking. Thanks.
