Re: pre-start check list? I think it's ready to go!
Posted by Steven f/AZ on April 02, 2008 at 12:42:13 from (216.67.213.217):
In Reply to: pre-start check list? I think it's ready to go! posted by Mike CA on April 02, 2008 at 09:18:34:
Mike CA said: (quoted from post at 09:18:34 04/02/08)
Janicholson said: (I assume you primed the oil system as we discussed weeks ago)
I primed the pump when I installed the new oil pan back in November. Hopefully everything is still set to go.
To re-prime the system, crank it over a bit with the spark plugs out so some oil gets pumped up to the top end and the bearings before you fire it up!
Can't wait to hear the good news!
