Re: F-12/F-14 Cylinder Heads
Posted by Kevin LA-CA on April 02, 2008 at 18:42:50 from (71.177.197.123):
In Reply to: F-12/F-14 Cylinder Heads posted by Dave Allgire on April 01, 2008 at 18:58:03:
My '37 F-12 has 3 studs for the valve cover (I am pretty sure.) As did the 2 replacements until I found a crack-free one.
One difference in the heads is the combustion chamber on one version (I think gasoline only version)is partially filled to increase compression.
I know of least two pistons for different compression ratios too. Not sure what the possible combinations are...
kevin
