Value of later model 140
Posted by Tab on April 02, 2008 at 19:06:13 from (4.252.38.47):
I located a 140 that has factory 12-volt and runs great, with no smoke or leaks. Front and rear hydraulics work stable and steady. Has the fast-hitch, but no pull-behind implements. Trans. and clutch feel good. Brakes will stop you, but are weak. Steering is fairly tight. It does come with PLENTY of cultivator attachments(many pieces). Tractor has original paint, with some surface rust, mainly on gas tank.Paint is pretty much faded away. Oily residue has preserved most of the engine and lower paint. Tires and all wheels are in decent shape. Even has a working fertilizer assembly. I can get it all for 2500.00. Should I "jump" on this? I've had a few bad experiences with Farmalls before, but I kinda like this one. Thanks for any input!!
