Re: IH 1466 Transmission Low Range Knocking Noise
Posted by Owen Aaland on April 02, 2008 at 20:53:38 from (65.165.246.59):
In Reply to: IH 1466 Transmission Low Range Knocking Noise posted by Jeff Kleypas on April 02, 2008 at 18:56:41:
Most likely a broken tooth on a gear in the range transmission. In high range the speed transmission output shaft is coupled to the pinion shaft in the rear end so no power is transmitted through any of the range transmission gears. You would most likely be able to see the problem if you remove the cover on the left side of the rear frame just in front of the brakes. Any repair involving replacing any of those gears means a complete disassembly of the rear frame. The differential has to be removed before you can take out the pinion shaft.
Flat rate for range transmission overhaul is 15.7 hours without a cab. Most likely there will be some final drive bearings that need replacing so any of that type of work is in addition to the 15.7 hours.
