Re: quick release muffler clamp?
Posted by Bob Kerr on April 02, 2008 at 21:24:15 from (205.188.116.73):
In Reply to: quick release muffler clamp? posted by Mike CA on April 02, 2008 at 18:22:44:
I don"t have the clearance problem , but last year when I worked on my H I had the hood off what seemed like every 5 minutes and of course that ment pulling off the muffler each time. I used good thick welding gloves which are pretty cheap and didn"t over tighten the clamp.It also helps to let it sit for a few min or the gloves will smoke and leave a hand print mark on the muffler! There may be a slot in the pipe of the muffler for clamping or may not be one. I would say you might be able to cut a slot in with a hacksaw so it will come off easier and still tighten up. Large wing nuts on the clamp might also help if you can even find them that size. I don"t set my muffler all the way down as it gets me just enough highth to keep the exhaust out of my face. I set it about 1.5 inches down the pipe.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
