Re: Final MD Hydraulic hoses and wiring
Posted by Sagebrusher on April 03, 2008 at 08:32:10 from (69.19.14.35):
In Reply to: Final MD Hydraulic hoses and wiring posted by Peculiar Farmer on April 02, 2008 at 19:15:50:
Hello Peculiar
Does your breakaway coupling have a swivel bracket attached to the hose side? The original bracket bolted to the right rear and center rear platform bolts. It had a flat portion with those bolt holes and an upright pin with a cotter key to hold the coupling on but still allow the breakaway to swivel. The original hoses ran straight back along the right side of the seat and gear shift. IH also supplied a hose guard that bolted to the platform and covered the hoses from the two way remote "Christmas Tree" to the breakaway.
Your hoses appear to be a longer than original. Do you have the other half of the coupling that stays with the cylinder?
If you email and would like I will take a couple of pictures of our setup and fwd them to you.
Also, if you decide to convert to Pioneers, please let me know if you would be interested in selling your breakaway. I could use one more assembly for our other M.
Best Regards Don
