Re: IH 444 hi/low problem
Posted by IH2444 on April 03, 2008 at 09:32:25 from (192.76.82.89):
In Reply to: Re: IH 444 hi/low problem posted by paridgerunner on April 03, 2008 at 06:03:26:
My 2050 has a reinforced rock bucket on it. About too heavy for most things. I run a 3/4 ton 3 point counterweight on mine. And have loaded rears.
Need to make a lighter bucket for it.
I think you can get the little filter at Napa. Case-IH for sure.
And you have 3 drains in the bottom to the best of my memory. And one in the bottom rear of the lift box. Fill the lift box and then the tranny/rearend fill.
If yours is like mine the lift box will only fill up to a point and then has an overflow pipe into the rearend sump.
