Re: F-20 sounds
Posted by Farmallgray on April 03, 2008 at 12:08:01 from (208.254.241.76):
In Reply to: F-20 sounds posted by farmall kirk, on April 03, 2008 at 07:59:32:
It wouldn't be the longer stroke because the F-20 is a 5" stroke and the M/6 had a 5-1/4" stroke.
They are two totally different engines with different cylinder heads/ports and different styles of manifolds.
F-20s will sound different with a kerosene vs gasoline manifold too. If they still have the cast elbow, they will sound different than with
a verticle straight pipe as well.
The F-20 and the Regular have the same basic engine but with different manifolds and they sound a lot different from each other.
If you retard the spark (or if the timing isn't right to begin with) on an F-20 it will really make them bark under a load.
