Re: Timing marks on 46 B
Posted by CNKS on April 03, 2008 at 17:25:53 from (216.144.104.128):
In Reply to: Timing marks on 46 B posted by dads b on April 03, 2008 at 15:43:35:
The others are correct. If you can't find the mark -- I promise you it is there -- Put # 1 at TDC, point the rotor on the mag to # 1 on the distributer cap, install the mag and rotate the top (coil) against the block, remove the coil wire and hold it 1/4 inch from the grounding nut on the mag body (switch pulled out), rotate the mag clockwise from the rear until it trips. You can do final timing by ear if needed. If it has a distributer the procedure is the same, except you rotate it clockwise until you get a spark from the coil wire.
