Re: Which came first: sawtooth or notched throttle
Posted by RustyFarmall on April 03, 2008 at 17:57:59 from (209.152.78.71):
In Reply to: Which came first: sawtooth or notched throttle posted by Tom Fleming on April 03, 2008 at 17:56:31:
Saw tooth came first. I think the notched style was introduced when the supers arrived.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
