Re: Horizontal slotted holes on underside of H liftall
Posted by Allan In NE on April 03, 2008 at 19:46:22 from (148.78.243.26):
In Reply to: Horizontal slotted holes on underside of H liftall posted by VA Gasman on April 03, 2008 at 19:32:53:
The "hole" itself was used as a pivot point on different lifting attachments.
As far as I know, the "keyway" was used with the special lifting tool used to remove/install the liftall pump itself.
The tool had two handles on each side of a pipe that was "keyed" into that keyed hole, which allowed two men to lower the pump assembly straight down and keep it from tipping while doing so.
Allan
