Re: Horizontal slotted holes on underside of H liftall
Posted by Chuck46 on April 03, 2008 at 20:05:38 from (64.136.27.230):
In Reply to: Horizontal slotted holes on underside of H liftall posted by VA Gasman on April 03, 2008 at 19:32:53:
Va, All belly pumps have this, it is a pivot point for the cylinder on mounted equipment. Look at the bottom, there is an open space in it. The pivot rod has a key shape, it slides in to the open space, then is turned so it is locked there in its operating position. Quite ingenious, Chuck
