Re: Farmall 140 wiring harness routing
Posted by Hugh MacKay on April 04, 2008 at 02:07:38 from (216.208.58.184):
In Reply to: Farmall 140 wiring harness routing posted by rdragoo on April 03, 2008 at 20:26:45:
rdregoo: the 140 is a bit different from SA, 100 and 130 in that the ignition wire to coil, is in the left side harness, and crosses the front of engine with the wire for right light, From the dash it's fastened to hydraulic unit hold down bolts. Depending on which 140 you have, serial number is important here, some have voltage regulator on clutch housing. Then it clips to bottom bolt that holds breather to engine block.
Across the front of engine it clips to top bolt of bottom coolant outlet on the left side and on the right side to the first bolt below the governor that holds engine front cover in place
