Posted by Mike CA on April 04, 2008 at 19:36:49 from (75.31.173.102):
In Reply to: Took my first drive posted by Mike CA on April 04, 2008 at 18:41:46:
Curt W. said: What's next?
I'd "like" to get the grill fixed before I put it back on. But that's a low priority under these leaks. So, I think I'll concentrate on ways to get the leaks stopped up for now. Soon I'm going to drive it down to my friends (about a mile away) to put the new rear wheels on it. Then I've got to try to fix up the rear tires a bit.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
