Re: How hard would this seal be to replace?
Posted by 1fortyfanatic on April 04, 2008 at 23:37:02 from (4.228.9.37):
In Reply to: How hard would this seal be to replace? posted by matt a on April 04, 2008 at 19:34:29:
Oh, and in answer to your question about draining, yes it would be advisable to drain first IF you intend to remove that lower seal cover. Two reasons, first you can drain to a clean pan and save the oil to put back in IF it's fairly new and clean. Second, you avoid having the oil smack you in the face and run down your arm (and all over the concrete) when you take the three bolt cover plate off.
Dave
