Re: FARMALL 560 TRANS FLUID
Posted by tn terry t on April 05, 2008 at 04:41:08 from (64.12.116.144):
In Reply to: FARMALL 560 TRANS FLUID posted by Haas on April 04, 2008 at 12:28:31:
something to check if you would crawl under the tractor there is a weep hole in the torque tube i cant remember where it is but make sure that weep hole aint stoped upsometimes the front seal for the transmission will weep fluid out and if the hole is stopped up the fluid will build up and can cause the clutch to slip my brother-inlaw and i where fixin to break our 560 in half to replace the clutch. his 75 yr old uncle said wait untill i can get over there. he crawled under there with a welding rod and unstopped the hole about a half gallon of stuff came gushing out of that hole i drove the 560 around about twenty min. no more slipping clutch that was about fours years ago still working just fine i would check the adjustment but i would try this also its a whole lot better than breaking it apart
