Re: How hard would this seal be to replace?
Posted by Bob M on April 05, 2008 at 05:17:23 from (69.205.123.154):
In Reply to: Re: How hard would this seal be to replace? posted by Mike CA on April 04, 2008 at 20:22:51:
Oops - I forgot to mention you gotta also unscrew the slotted drive coupling as mentioned above (thanks Steve!).
No way to isolate the leak before beginning repair. Rather drain a couple gallons from the tranny, or else run the front end up a steep ramp so the oil is at the rear of the transmission. (If it's been leaking a while the oil level will already be way low...)
