Re: How hard would this seal be to replace?
Posted by Bob Kerr on April 05, 2008 at 05:40:29 from (64.12.116.73):
In Reply to: How hard would this seal be to replace? posted by Mike CA on April 04, 2008 at 19:34:29:
Hi Mike, You can use a can of spray brake cleaner to spray around the shafts and then run it a min or so and see which one is leaking. the leak will show right up! Bad news is you will have to drain almost all the oil out if doing the lower shaft. I would say at a lesurely pace it should only take a few hours to replace the seal. When working on greasy parts, I use a plastic storage tub with kerosene in it and a parts cleaning brush to clean them up.
