Re: Hey You Smart Guys!
Posted by IaGary on April 05, 2008 at 07:32:40 from (67.55.192.138):
In Reply to: Re: Hey You Smart Guys! posted by Allan In NE on April 05, 2008 at 06:22:49:
Ok Allan here is the deal.
If you run that 686 and it only burns 3 gal an hour on that disc, you will get about 3 acres disced on a gallon.
Now if you put a 20 footer behind the 1066 you will burn about 6 gallon an hour and get about 2.5 acres per gallon.
So 40 acres will take 13 gallons on the 686.
The 1066 will take 16 gallon to disc that forty acres
Your savings of about $14.
But you would spend 5 hours on the 686 and only 3 on the 1066.
Is your time worth more than $7.00 an hour as well as putting 5 hours of wear on the 686 and only 3 hours of wear on the 1066.
Your call.
Gary
