Posted by Dave_Id on April 05, 2008 at 08:23:41 from (70.112.233.145):
In Reply to: H starts then dies posted by EH in KS on April 05, 2008 at 07:56:13:
Take the fuel line off, and let it run in a gas can for a couple of minutes to ensure there is no blockage in the tank itself. It sounds as if the carb fills up, you start and run it, then the carb is starved for gas, it kills, then slowly fills up again to enable restarting.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
