Posted by Michael Soldan on April 05, 2008 at 09:40:02 from (24.235.58.254):
In Reply to: H starts then dies posted by EH in KS on April 05, 2008 at 07:56:13:
Thats a typical fuel problem, and you have not checked it out accurately. As others have said, having fuel run out at the carb does not mean you have unrestricted flow, Fuel should flow continuously when you pull the line and let it into a container, after a couple of minutes you will know. Incidentally your blockage will be in the screen in the fuel bowl, very typical of an H. I had a neighbour who had tractor problems and he said he had fuel flow..and he did, it flowed real well for about eight seconds then it dried up..if you waited a few minutes until it trickled in you would have good flow again...for about eight seconds.......
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
