Re: What could cause no oil pressure?
Posted by 1fortyfanatic on April 05, 2008 at 15:49:51 from (4.228.9.134):
In Reply to: What could cause no oil pressure? posted by Zac Breazeale on April 05, 2008 at 14:57:02:
Mike. Hugh on this forum, said something really wise once, and I think it applies here even though he was at the time talking about hydraulic pumps. He said, how long will your heart last without blood? That's how long your engine will last without oil. Do you really want to risk it?
If not, I would take the gauge, the tube line, and the sender unit if there is one, off and inspect every part. If the line and sender check out (clean them thouroughly and blow out the line) then replace the gauge before you even start it up again. The risk is too great. Your oil pump MAY be fine, but what if it isn't? Don't seize that engine up when you are so close.
Dave
