Re: What could cause no oil pressure?
Posted by Haas on April 05, 2008 at 16:22:02 from (12.65.36.31):
In Reply to: What could cause no oil pressure? posted by Mike CA on April 05, 2008 at 14:57:02:
You can test the gage with air pressure. If you have a compressor that has a regulator, set the regulator to 40 psi and get some fittings to adapt to the gage (1/4 inch pipe threads??) and screw on the gage and then turn the regulated air supply on.
