Disconnect the line from the gage. Crank the tractor with the switch off so it doesn't start. Oil should shoot out of the line. If it does replace the gage. If no oil, proceed to step 2. 2) Remove the line and use one of those rubber tipped blowguns to check the line, to see if it's plugged. If it's plugged, clean it , reinstall and check pressure. IF it's clear go to step 3. 3. Crank engine with oil pressure line off engine. Oil should shoot out of the port. If it does now you KNOW it is the gage. If it doesn't we're in deep doo doo. Just common sense working upstream to find the source of the pressure problem.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
