your question has kept my brain busy all afternoon, as there was a memory from 40 yrs ago when the same thing happened on dad's super c. i keep wanting to say that back then, i put the assembly together wrong, and had the 2 pull links aimed 180 degrees off. but there is only 1 way that stuff will go together and still line up with the pin that keeps the assy from turning, right? marv has a possible explanation, but its more likely that the housing edge was planed than the transmission case surface. i'd never heard of someone milling the surface. it would have been cheaper to just get new disks in the first place. it sounds like you could get it going by spacing the housing away from the trans case with a washer. you'd have to put silicone sealer around the housing to keep the crud out if you used washers. let us know what you find.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
