I have had the same problem, even with a new pump. I used the IH packing in various amounts with no success, and then switched to the rope. It still leaked, but after using the tractor several times it stopped. I have been told that the use of loctite on the packing nut will help. Mine worked loose. Run it a while and see what happens. This is a somewhat unusual problem as most people on this forum have had good luck with the IH packing. IH could have changed suppliers. As far as the wrench, a 7/8 inch stubby wrench works ok for tightening the nut in case it leaks. The springs, etc have to be removed otherwise. Also, you may need more than 1.5 wraps, I think 3 of the IH packings are about the minumum.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
