Farmall Tractors Discussion Board
Re: Help!! Correct 6 volt battery for Farmall A.
Posted by Phil Auten on December 17, 1998 at 11:24:43:
In Reply to: Help!! Correct 6 volt battery for Farmall A. posted by Marty on December 17, 1998 at 08:55:15:
Marty,
If you have a battery that fits the battery box, just carrt it to the auto parts store or service station and they can get the correct battery for you. You shouldn't need a real heavy duty battery capacity wise since these engines are low compression and don't take a lot of power to crank over. You will, however, need to let the person asissting you know that the battery is for a tractor. The construction should be matched to the use, as tractors vibrate and bounce around more than cars/trucks.
Good luck,
Phil Auten
Post a Followup
: Re: Re: Help!! Correct 6 volt battery for Farmall A.
