Re: M belt Pulley Oil
Posted by Slappy on April 07, 2008 at 17:32:55 from (143.88.85.122):
In Reply to: M belt Pulley Oil posted by Zach Bouchard on April 07, 2008 at 17:26:56:
The pulley drive uses oil from the transmission that gets thrown up into the casting as the engine runs. If you pull the pulley shaft cover out and drain the oil (a cup or two will come out), you might want to add a bit through the pulley casting plug, but if you have oil in the transmission the pulley should be getting lubed too.
