Re: M belt Pulley Oil
Posted by Bob M on April 07, 2008 at 17:42:56 from (69.205.125.108):
In Reply to: M belt Pulley Oil posted by Zach Bouchard on April 07, 2008 at 17:26:56:
Zach - The belt pulley gearbox is lubed by gear oil thrown up from the transmission - no separate oil fill required.
However if the gearbox has been removed and emptied of residual oil, it doesn't hurt to dump a quart or so of fresh 80W-90 gear lube into the fill opening to pre-lube the gearbox after it's mounted back on the tractor.
