Don in Texas said: (quoted from post at 04:03:32 04/08/08) Bought a 1976 Cub several years ago that was having the same problem. After getting it home, I installed new points and condensor and a voltage reducer between ignition switch and coil. The reducer was intended for a Plymouth. The 12 volts was burning points up.
That's because somebody installed a 6V coil on your Cub by mistake.
If you install a "voltage reducer" (aka ballast resistor) when it is not necessary, you will get a weak spark and the tractor may not run at all.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
