Posted by Bob M on April 08, 2008 at 07:37:05 from (151.190.254.108):
In Reply to: H Farmall clutch? posted by D-B in MN. on April 08, 2008 at 06:31:59:
Your problem could be as simple as the clutch pedal linkage needs adjustment.
To do this pull the pin from the clevis at the front end of the rod connecting the clutch pedal to the clutch cross shaft arm. Loosen the locknut, then screw the clevis up or down the rod as required to adjust the free play.
Correct adjustment is a bit over 1" of free play at the pedal before the throwout bearing begins to push on the clutch mechanism. (You can feel the free play by moving the clutch pedal by hand...)
You may be lucky and find this solves the problem!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
